LS Dyna
LS Dyna
Forming Crimp Material Model
    • s.breyer
      I tried different material models for a crimp simulation but as you can see in the picture, the crimp is too squashed on one side. It should look like the one on the right in the picture.
      Material models I tried (also with extra high Young's Modulus):
      Mat01_Elastic, Mat03_PlasticKinematic, Mat24_PiecewiseLinearPlasticity, Mat36_Barlat, Mat112_FiniteElasticStrainPlasticity.
      They all give the same problem result.
    • Raman Babu
      It seems like some different BCs, along with different material are used in your case
      Can you share some pics of your simulation setup?
      We utilize the following BCs to predict the deformed shape.
      Raman Babu
    • s.breyer
      here is a quick overview about my setup and one example of a material model (as I said i tried many different).
    • Raman Babu
      Please specify the constraint to *MAT_rigid through CMO =1 for rigid parts
      Also, you can specify the Die and tool as rigid.
      Loading condition:
      Other conditions:
      Apply velocity to a tool body
      Displacement on the wires in the axial direction
      Rigid Body Constraint
      -Anvil is fixed
      -The tool is free in velocity direction but fixed otherwise
      Please try to readjust your setup and let me know your findings.
    • s.breyer
      just to clarify, i am using the free student version
      rigid body parts (thickness 0.05):
      • light blue part (110111 – only move in Z)
      • bottom die (111111 – no move)
      wires – solid part (see material in the picture above):
      • end of wires (111111 – the long end is fixed)
      movement (only light blue part is moving to form the crimp)
      i used z-displacement, so no “velocity”, just prescribed_motion_rigid DOF=3 & VAD=2
    • s.breyer
      In the picture you can see the critical point. The punch makes pressure from above and the crimp becomes thinner. I still have no solution for this (im using LS-Dyna free student version)
    • Raman Babu
      Can you please fix the wire & other deformable body only in the normal to wire axial direction in place of fixing it in all directions?
      Raman Babu
    • s.breyer
      i did and nothing changes at all. I still have problems with the volume constancy of the metal. The piece of metal should only roll inwards, but not be deformed in width.
Viewing 7 reply threads
