Ansys Products
Ansys Products
Maxwell – Axial Flux Motor
    • sezeraysebetul
      When I validate the axial flux motor that I designed in Maxwell, there is no problem, but when I submit it for analysis,
      I receive the error "Please contact technical support and report installation error code 1000."
      What is the reason for this and what do I need to fix?
    • MirandaH
      In order to rule out of installation issue, could you please give an example file a try see if this error exists?
    • sezeraysebetul
      I analyzed one of the sample files. No such problem was found.
