April 20, 2020 at 10:47 am
lepetitprince
SubscriberHello,
I have downloaded the academic version of Ansys product, AnsysACADEMICSTUDENT_2020R1_WINX64 to be exact and I cannot start the installation process. I unpack the archive and double click the setup.exe file. I run it as administrator.
I closed every application I had opened, but I cannot click on anything there. Literally, it's like clicking on text that doesn't do anything. I tried to click to the Getting started - Installation , I expected pdf file to be opened but nothing really happened. I cannot pass that screen.
April 23, 2020 at 7:04 pm
tsiriaks
Ansys EmployeeCheck this
/forum/forums/topic/discovery-live-installation/
April 23, 2020 at 7:14 pm
lepetitprince
SubscriberThank you for your answer. I solved this in the meantime on my own I just forgot to report back.
I unpacked the installation archive to the desktop so it didn't work. I moved the installer to D
and it run properly.
When I tried to run workbench, it didn't work because of ? in my username, so I opened new user account in windows without non-english letters and just run the program I already installed. And it worked.
Is there any way to get it (workbench) to work with AutoDesk Inventor though?
April 23, 2020 at 7:33 pm
Divya Shree Surendran
Ansys EmployeeHi,
You can run the CAD configuration Manager with Right click and Run as Admin from Start Menu > ANSYS
Then click the checkbox for Inventor and select the Workbench Associative Interface Option > Next > Configure selected CAD interfaces
Does it say success?
After this, when you open Inventor > Do you see Workbench Plugin?
April 23, 2020 at 7:46 pm
lepetitprince
SubscriberPrerequisites ..... Configure Success
AI Workbench PlugIn ..... Not Configured
CAD Configuration log file was written to location:
Program FilesANSYS IncANSYS Studentv201CADConfigLogsLatestCADConfigurationMgr.log
That's all I get. The log says:
Invalid Inventor Dll File Path in createAnsRegistryXML2
Program FilesANSYS IncANSYS Studentv201aisolCADIntegrationInventorwinx64DSPlugInAICOM.dll
No valid Inventor installation detected
Writing packageinfo to: C:UsersMarko Todorovic.DESKTOP-MKFBFJPAppDataRoamingAnsysv201ProdConfiguninst_data.dat
WritePackageInstallData Succeeded.
SpaceClaimEngineering Not Detected
Saving to
Program FilesANSYS IncANSYS Studentv201commonfilesCADCADConfigurationInfo.XML
WriteUpdateConfigurationStatusFile Update Success
Everything is installed on D partition since the laptop has 128gb SSD and it's not enough for CAD software. Is that making a problem here?
April 24, 2020 at 11:15 pm
tsiriaks
Ansys EmployeeThis functionality is not included in ANSYS Student version.
You can check
https://www.ansys.com/academic/free-student-products
select the product -> "what's included" -> "Geometry Import"
- The topic ‘Unable to start the installation process’ is closed to new replies.
6425
