Electronics
Electronics
Got any faster or perfect ways to see the Electric field between two electode?
    • ngv-wg22
      The things now I create a box and assign it as an Oil, and create two hemisphere electrode to act as the ASTM D1816 test method. In the Simulation, I set one side of the electrode is 60kv another side is 0kv because I want to see the breakdown voltage occurs or not but the things is I want to see the Electric field. I got do two version for seeing the Electric field can help me see it the way that I set for investigate the Electric filed correct or not? Or you got a way to see the Electric field faster
    • ErKo
      Hi
      I would suggest to post this in the Electronics forum (this forum is for SC and Discovery mainly and 3D CAD design).
      All the best
      Erik
    • Miranda Hourihan
      hi, did you plot the field on a sheet object?
    • ngv-wg22
      how to plot it i just right click the sheet and choose field only. The things that i want to ask is it correct to determine the elecfield like that?? Or should i change a way to do it? The electric field that i want to see is between this two electrode when the breakdown voltage occurs
      • Miranda Hourihan
        This works! You can also select the XY/YZ/XZ plane and plot it on to see a larger area.
    • ngv-wg22
      But is it a correct way to see Electric field?? Bcs i use the formula of E = V/d to find the breakdown voltage that is not make sense. So i still struugle
      E = Electric field, V = BDV, d = gap distance between two electrode in cm (i design it 2mm)
Viewing 4 reply threads
