Named Selection (or groups) not transferred to Watertight Meshing for 2D
    • moritz.ursprung
      I have the problem, that the named selection or groups (as they are called in SpaceClaim) that I define in SpaceClaim are not transferred to the watertight meshing for 2D geometries.
      If I set up a 3D geometry the group names from SpaceClaim are transfered and I can select them as "labels" when adding element sizing for example.
      Am I missing something or is this not supported for 2D? Selecting edges and adding labels really does not work well, once you are inside the watertight mesher.
    • CFD_Friend
      Hi
      Watertight workflow does not support 2d geometries. For 2d meshing, there is a separate 2D Meshing workflow option alongside watertight workflow.
