March 10, 2020 at 5:25 amjohnfidesSubscriber
   I made a very simple example in ansys maxwell and want to calculate the I ^ 2xR loss of the copper bar you see in the figure. I selected eddy current as the solver and made a current exciation. I looked at ohmic loss. However, I could not find the values I calculated. In addition, as the size of the region I throw out of my bar changes, ohmic loss changes. What is the reason for this and how can I correctly calculate ohmic loss in this bar?
Thank you for your help.
March 10, 2020 at 9:24 amjohnfidesSubscriber
Thank you for your help but I am using ansys maxwell 2015 version. Can't I do it right with this version? By the way, my conductor in reality is not the litz.
Thanks again.
March 11, 2020 at 5:30 amjohnfidesSubscriber
Thanks again.
- The topic ‘DC loss on the bar’ is closed to new replies.
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- How to customize pulse waveform and injection site in microstrip array
- 180 Degree Phase Shift When Measuring S21
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
1311
591
569
525
366
