3D Design
3D Design
Ansys fluent enclosure subtraction
    • konka92
      Hi  am performing a VWAT analysis and I wanted to subtract my model from the enclosure but space claim comes up with an error stating that it could not subtract. If  someone can please help me to fix up this it would be really great thanks in advance.
      What type are the VAWT bodies?
      Moving to geometry.
    • Keyur Kanade
      make sure that you have a solid for subtraction.
      if you have solid, please check if it has any errors. you can check it by selecting in structure tree --> right click --> check geometry.
      Also you can try creating a enclosure manually and then use 'Combine' command for subtraction.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • konka92
      Yes it is a moving geomentry body
      But is it a solid? Or just a collection of faces?
    • konka92
      Hi I have finally resolved using combine and split body option. thank you so much for your inputs.
Viewing 5 reply threads
  • The topic ‘Ansys fluent enclosure subtraction’ is closed to new replies.
