How to get a correct force displacement diagram in workbench ?
    • hamzaDZ13
      Good morning guys , on a steel frame subjected to a linear increasing load applied as a cyclic loading i applied the loading protocol shown below to get the force -displacement diagram shown on the curve down , i used a tabular data but the results doesn't match with the disered ones .  any help here ! is it the correct methode using and do i have to use some commands to get a correct curve ?
      thanks in advance .
      cyclic loading
      Did you use Directional Deformation? That goes positive and negative.
      Because Total Deformation is always positive.
    • hamzaDZ13
      yes i used the directional deformation it's gives postive and negative values as shown above but not as the disered curve .
      I don't see any negative values in the X axis of your plot.
    • hamzaDZ13
      yes exactly there is no negative values on the X axis , the displacements given on the X direction at the top of the higher comumn , so wht you think i did missing or what's your suggestions to make it correct ? do i need to specify  a deformation of  a point from the frame not all of it ?
      In the first image, I see you have applied +/- displacement to an edge on the top right corner of the structure.
      Where is the Directional Deformation scoped to?
    • hamzaDZ13
      i didn't understand your last question , but  the directional deformation is set at the X axis , see in the chart controls when i put the force reaction at the X axis the curve is changed , there is a +/- values at the X axis but no on the Y axis ?
    • saifali
      Can you send the file?
    • hamzaDZ13
      how to send the ansys mechanical  files here , there is just images option ?
    • hamzaDZ13
      here i zip it on google drive , i don't know if that will help you to open it there ?
Viewing 10 reply threads
  • The topic ‘How to get a correct force displacement diagram in workbench ?’ is closed to new replies.
