February 6, 2025 at 9:55 am
William D.
SubscriberHello, I'm designing a bearing in ansys Rigid Dynamics and encountered the error "Only rigid bodies and flexible bodies which are used in Condensed Parts are allowed in the current analysis". I scoured the entire Internet trying to solve this problem. I tried different types of contact and joint.
My bottom cover is a rigid body, (part of the ground) is a separate component, the balls are a separate component (shared topology - shared) and the top cover is a component. As far as I know, a component in geometry is a condensed part. What should I do? Thanks in advance.
February 6, 2025 at 10:30 am
ErKo
Ansys EmployeeHi
The message is I hope clear I believe (flexible bodies need to be condensed parts).
There are some tutorials online about this and how to define condensed parts.
https://www.youtube.com/watch?v=hKObnqWXf6M
https://www.youtube.com/watch?v=IXDrYV5JBTc
For more on theory see our help manual and this course
https://www.youtube.com/watch?v=OzEEgODBdo4
https://innovationspace.ansys.com/forum/forums/topic/condensed-geometry/
All the best
Erik
February 10, 2025 at 3:43 pm
William D.
SubscriberÂ
Thank you! This really helped solve the previous problem. Now I organize the movement of the balls through friction, and not through joint. But now the old problem has appeared in a new place. Shaft+Screw is a body that is part of the Shaft+Screw+Up part via shared topology – shared. As far as I understand, the program requires that I also make Up part of my Codnensed part, and when I do, an error appears about the contact between the Condensed Part and other bodies (Balls, in my case). Joint – Moment force applied to the body Shaft+Screw. What should I do? Thanks in advance.
5994
1307
