TAGGED: design-exploration, error, harmonic-analysis, parameter
February 4, 2025 at 5:43 pm
martinazzo
SubscriberI am trying to do a parametric study that includes a Harmonic Response analysis after a Modal analysis. When I try to alter parameters and run a deisgn point, I get the following error: "Unable to Start the Mechanical editor":
This error only happens when the Harmonic Response block is added to the model, if I try to update a parameter and run a DP having only a Modal analysis block, everything works normally.
I am also unable to delete the Harmonic Analysis block from workbench after this happens, when I try to delete it the following message shows:
However, I can delete it from inside mechanical. Also, if instead of running the design point from workbench (in the Parameters tab) I set it as current, open the editor manually and solve from there, everything works fine, the Harmonic Response is able to solve normally, so the problem seems to be in using the parameters in conjunction with the harmonic response analysis.
I am using a geometry imported from Solidworks and using Ansys 2024 R2, no problems with licenses as I can open and run the editor normally if I do it manually.
I have tried to run the same simulation file in other machines and the same errors happen. I have tried re-installing ansys (making sure to do so as administrator), tried to change the the v242 folder to v242.old and still the same thing happens.
I also tried to create an entirely new workbench file, with a new geometry (a solid block, for testing) using the modal and the harmonic response analysis, without changing any configurations from default, and still, the same error happens, but I had previously done this kind of analysis without a problem in older versions of ansys.
Can anyone help me find what is causing this? Thank you!
February 5, 2025 at 2:18 pm
Gary_S
Open the Modal Analysis
File > Export > Mechancal Database .mechdat
Create a New Project
Drag / Drop the .mechdat file into the Project schematic.
Promote Parameters as needed. Copy in DP Parameter input values from the old Project, etc.
Save the New project. -
February 5, 2025 at 2:24 pm
martinazzo
SubscriberHi Gary, I tried exporting the .mechdat file into a new project as you suggested, but nothing changed in the outcome, I still get the same errors.
Do you have any insights as to what might be causing this?
February 5, 2025 at 2:47 pm
Gary_S
Ansys EmployeeThe issue might be related to license level.
Can you tell me the license level you are using? You can see it in the banner, or File > Licensing > License Options
====There was a defect only seen in Linux, it probably does not apply here.
In the Modal Harmonic, is the “On Demand Expansion” Option set to Yes ?
If so try set to No. -
February 5, 2025 at 3:34 pm
martinazzo
SubscriberI have had this issue using both Premium and Enterprise license levels, always using Windows 11.
"On Demand Expansion" is set to No.
February 5, 2025 at 3:39 pm
Gary_S
Ansys EmployeeLets rule out licensing
Exit Ansys apps.
In %TEMP%\.ansys, delete all the files. (note name is (dot)ansys)
Start Ansys and reproduce the failure.
In %TEMP%\.ansys, examine the log files with any text editor.
Are there any indications of license checkout failure ? -
February 5, 2025 at 3:51 pm
martinazzo
SubscriberDeleted files and reproduced the failure as suggested, log files indicate the license checkout was successful, but I still get the same error when trying to run the simulation from workbench
February 5, 2025 at 4:13 pm
Gary_S
Ansys EmployeeAre you using the latest Service Pack for 2024R2 (I believe it is SP4)
Are you by chance using Windows 11 24H2 ? -
February 5, 2025 at 4:36 pm
February 5, 2025 at 4:43 pm
6485
