February 3, 2025 at 4:01 pm
sivaraman-s
SubscriberHi all,
I have been trying to work with iso-surfaces across time steps.
Here’s what I wanted to achieve:
· At time t₁, I generate an iso-surface over a certain set of cells in my domain from time step 1.
· At time t₂, I obtain another iso-surface from time step 2, which may overlap with or include different cells than at t₁.
· After t₂, I want the total spatially integrated iso-surface to include all cells that were part of the iso-surfaces at t₁ and t₂.
Is there any specific method available to perform such operations. My simulation is a multiphase vof model.
Thanks in advance for your help.
February 3, 2025 at 4:09 pm
Forum ModeratorYou can have a look at surface export (possibly as a VRML file) and then import>imprint.
February 3, 2025 at 4:32 pm
sivaraman-s
SubscriberHi Rob,
Thanks for responding. The surface imprint option works in .stl, .msh, .cas files if I understand right.
I want to, for example, export iso surface created in time step 1, for example as shown below. This way I have few formats of exporting the iso surface, so with this appraoch can I still use surface imprint to combine the iso surface from this time step with the second time step?
February 3, 2025 at 4:43 pm
Forum ModeratorAh, they've changed something. I've done something "clever" in older releases. I'll have a look, but may not be able to share immediately if it's really "clever".
February 3, 2025 at 4:44 pm
sivaraman-s
SubscriberThanks Rob, looking forward to the response.
6510
