February 7, 2020 at 9:26 pm
chandus127
SubscriberHello,
I have been analyzing a co-simulation setup, which has a motor imported from Maxwell 2D into Simplorer. The motor is a four phase one, but imported version shows five terminals, all of them having in and out pins. I am confused with pair of terminals for motion setup. I have few questions on this,
1. What are those pair of terminals named as motion setup1, shown in image.
2. If it is for mechanical load setup! May I know how to connect them without resulting in error.
3. It is taking too much time to run the model When incoming end is grounded and outgoing end is loaded. Is there a way to speed up the simulation?
March 1, 2020 at 8:20 pm
GayaniDeS
SubscriberHello,Â
I have been trying to import 3 phase motor to the Simplorer.Â
Did you find what are those pairs of terminals named as motion setup?
Thank you -
March 2, 2020 at 5:43 pm
chandus127
SubscriberÂ
Yes, I came to know one has to be connected to set speed and the other terminal has to be for the mechanical load. The mechanical load might include torque "F_ROTB" and mass "MASS_ROTB" and speed "V_ROT". If you reverse the speed and mechanical load connections motor will rotate in the opposite direction.Â
However, the induced voltages across windings are not balanced and showing DC offset as well, the torque also fluctuating and average torque is showing as zero.Â
Note:
I have excited the imported model from maxwell with AC current sources to see it's functioning and then will proceed to build controller.Â
The maxwell design or FEA of machine has shown promising results but things have changed when I imported into simplorer with external excitation.Â
I really appreciate if anyone can suggest inputs on the same!
Thanks
March 8, 2020 at 8:23 pm
GayaniDeS
SubscriberThank you for your reply.
Did you encounter any problem like this "[Sim2000] Error - FEA1: ERROR - could not find a transient operating point before launching Maxwell >> Calculate at t=0.0005" when doing your cosimulation?Â
I did try changing the time steps.The required time step was very small which took ages to solve. Do you have any idea about this one?Â
I would be glad to hear your response.
Thank you -
March 10, 2020 at 2:58 am
March 10, 2020 at 3:09 am
GayaniDeS
SubscriberThank you for your kind reply.Â
Were you able to resolve that error using these settings?Â
What is the value you used as frequency?
I tried changing the time settings, but I got the same error.Â
Kind Regards
Gayani -
March 10, 2020 at 3:13 am
chandus127
SubscriberTry stop time as 0.0015 and time step as 3.75e-05
March 10, 2020 at 3:25 am
GayaniDeS
SubscriberI tried that value. Still the error is same.Â
I am building a Field Oriented Control of a Motor.Â
I have a doubt about how Maxwell takes its first current values at the start, As I am controlling the motor using the outputs obtained from it. -
March 10, 2020 at 3:37 am
chandus127
SubscriberI have excited the imported FEA model with current sources only. I didn't get any promising results so far though the simulation is running. I can see warnings on the convergence. I am still looking for a way to fix it and will go for the next step of modeling if it works well with the current sources.Â
Give a try by exciting with current sources. Do step by step.Â
March 10, 2020 at 3:43 am
March 10, 2020 at 3:59 am
GayaniDeS
SubscriberI'll try that and let you know if the problem is solved.Â
Thank you for your kind response.Â
Regards
Gayani -
March 10, 2020 at 9:30 pm
GayaniDeS
SubscriberHi ,Â
I am using SVPWM for the inverter. Inverter is fed with a rectifier circuit connected with a capacitor in parallel.Â
It was found when the SVPWM module is connected with the capacitor voltage it gives a error like that (Even though the initial voltage of the capacitor is given). And when SVPWM connected with a separate DC source there is no error.Â
There is a possibility that FEA cannot initiate because it doesn't work untill the capacitor is fully charged.
Hope this might give you an idea. -
March 11, 2020 at 2:04 pm
chandus127
Subscriberdid you try connecting a resistor in series with the capacitor?Â
May 7, 2020 at 2:29 am
June 1, 2020 at 12:15 pm
Teddy
SubscriberHello Gayani & chandu
Im also working on 3phase motor control , using FOC method.
I also encountered the same problem when i use the outputs
Did you solve your problem?
Please contact me on ted5082@gmail.com -
September 24, 2020 at 1:46 pm
April 23, 2021 at 12:40 am
pillai
Subscriberhi ndoes any one know how to implement the mechanical dynamics should it be on motion Setup Out?. -
August 23, 2023 at 1:27 pm
Sampath kumar A V N
SubscriberWhy the rotation input is given to the motor along with load torque... Generally due to mechanical transient, it should give speed at the given load torque right????????
- The topic ‘Motion setup terminals in Ansys Maxwell-Simplorer/cosimulation’ is closed to new replies.
6625
1311
