January 22, 2025 at 12:43 pm
cbur
SubscriberHello,
I'm having a problem with the sheetmetal tab in Discovery. In the French version, it is impossible to modify the sheet properties (thickness / bending radius / K factor), which makes it impossible to use Discovery in French.
In addition, do you know if it is planned in the future for discovery the possibility of ‘multi Tab’ (possibility of opening several tabs of different design)?Thanks
January 22, 2025 at 3:16 pm
Devendra Badgujar
Forum ModeratorHello Charlie,Â
Thanks for bringing this to our attention. I will forward this to the development team.Â
Currently we do not have the information on multi tabs in Discovery. We will let you know as we hear more in the coming releases.Â
DevendraÂ
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Data Center Simulation
- Overlapping contact face
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Inventor 2025 files
- Issue Seeing Explore
- solidwork parameters for optimization in ansys
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- Fan flow simulation
807
599
591
366
