January 13, 2025 at 9:26 pm
Alex
SubscriberHello, why are the default 'Inclination of Equator' parameters for Mercury set to 28 degrees, and Pluto set to 0 degrees? The Thermal Desktop user guide states that the Inclination of Equator "is the angle between the planet’s equatorial plane and its ecliptic plane." May someone please help me understand how these values were determined?
January 14, 2025 at 3:55 pm
Doug Bell
Ansys EmployeeI will look into this and see why these values do not agree with the information I have found.
You are able to set the defaults for orbits, including the planetary data.
Follow these steps
- On the Thermal ribbon tab, expand the Common panel
- Use the first Defaults: * drop-down to find Default: Orbits
- Set any values you wish to use
- Create a new orbit to use the new defaults
If you perform steps 1-3 in a black drawing and save the drawing, you can start any new project with your desired defaults.
February 4, 2025 at 7:20 pm
Doug Bell
Ansys EmployeeNote that planetary information such as equatorial inclination can change over time. If we update the values, we will update using current information. You should ensure that you use planetary data expected when your system will be orbiting or on that planet.
6450
