January 10, 2025 at 2:49 am
cchy870919
SubscriberI am using calculator to calculate the maximum electric field value, the formula uses Maximum(Surface(Region), Mag(
)), but this is considering the overall electric field, I want the maximum electric field in a certain range. How to do this? thanks -
January 15, 2025 at 6:42 am
Gia
Ansys EmployeeCan you explain in more detail what you mean by 'overall electric field' and 'maximum electric field in a certain range'?
January 17, 2025 at 12:58 pm
crowd9846
SubscriberFor example, for a box, us maximum(Surface(Region), Mag() * ((x >= 0) && (x <= 10) && ...))
January 17, 2025 at 6:00 pm
Gia
Ansys EmployeeFirst, define a box object that covers your search area. - Next, intersect or subtract it from the larger object, and then re-solve the model.
Then you can simply use the expression maximum(Surface(New_Object), Mag_E)
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Core Loss in ANSYS MAXWELL Eddy Current solution
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- simplorer-maxwell
1540
1386
1230
