Ansys Learning Forum Forums Discuss Simulation LS Dyna Heart Electrophysiology Model from ANSYS tutorials – help required Reply To: Heart Electrophysiology Model from ANSYS tutorials – help required
gdickey2
Hello Raman, thanks very much for your reply.
I would love to test to see if I can get it to run with the DEV solvers you mentioned, however, I don't have access to DEV solvers. Would you be able to advise me on how I can get access to these DEV versions (e.g., DEV-115080-g88d11f119d as you mentioned or LS-DYNA MPP DEV-96951)? Additionally, do I need special licensing to use these? Right now I'm using it for academic purposes.
Thank you, Grant.
