Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Joint force probe output data in global reference frame. › Reply To: Joint force probe output data in global reference frame.
January 8, 2025 at 3:53 pm
dlooman
If you only have 1 or 2 joints you could use the command fsum to get the joint forces in global coordinates. The procedure would be to create a named selection for one of the faces the joint is scoped to and then issue the commands below:
cmsel,s,face_name
fsumÂ
allsel
