Electronics
Electronics
FLEX PCB S-PARAMETER EXTRACTION
    • vanithkumar_balasubramaniya
      While extracting s parameter for flex pcb in Ansys siwave , showing below mentioned error.
      No planes detected
      Solution canceled: No significant planes detected in design.
      help us to fix this issue. for flex pcb s-parameter extraction do we need enable options in ansys siwave.
    • Aymen Mzoughi
      SIwave is not a 3D solver. Try using HFSS 3D Layout instead.
      You can export your design from SIwave to 3DL
