Ansys Learning Forum Forums Discuss Simulation General Mechanical Joint force probe output data in global reference frame. Reply To: Joint force probe output data in global reference frame.
harshvardhan.negi
In Ansys Rigid Dynamics solver, the joint constraint forces and moments are always reported in the joint reference coordinate system. If you need the values in the global reference frame, you might need to perform a coordinate transformation outside of Ansys.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
