January 5, 2025 at 5:10 pm
josegegas
SubscriberHello.Â
When one adds a joint probe to a rigid dynamics simulation, for instance to read joint force or torque, by default Ansys outputs the values expressed in the reference frame of the joint:
I would like the values expressed in the global reference frame, but Ansys does not give this option in the dialog. How can I do this?
Thank you in advance.
January 7, 2025 at 11:24 am
Harshvardhan
Ansys EmployeeHi,
In Ansys Rigid Dynamics solver, the joint constraint forces and moments are always reported in the joint reference coordinate system. If you need the values in the global reference frame, you might need to perform a coordinate transformation outside of Ansys.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines) -
January 8, 2025 at 3:53 pm
dlooman
Ansys EmployeeIf you only have 1 or 2 joints you could use the command fsum to get the joint forces in global coordinates. The procedure would be to create a named selection for one of the faces the joint is scoped to and then issue the commands below:
cmsel,s,face_name
fsumÂ
allsel
6765
1330
1102
