General connection between main flow path and circumeferential groove in CFX
    • zahlenritter
      Dear community,
      I am trying to simulate an axial compressor with a circumferential groove, but the interface
      between main flow path and groove is not working as expected and just generates a solid wall there.
      To simulate the influence of circumferential grooves I am given a mesh of an axial compressor.
      In a CAD-Software I construct my groove, which I importat and mesh in ICEM. Finally I load the
      mesh as a .cfx5-file into my case. I create a domain interface between compressor shroud and the groove
      side, pointing towards the shroud. For non-overlapping part at the compressor I apply a no slip wall as a a nonoverlap
      Condition.
      During postprocessing I noticed that the interface between both meshes is treated as a wall and not an interface with momentum exchange.
      I suspect that small geometric differences which are not visible, cause the meshes to not exactly match in the radial direction. As a result
      the no slip conditions is applied at the whole shroud.
      But how do I fix this problem?
      Best regards
    • V.P
      The reason is that the distance between the interface faces is above the tolerance level. You have to keep both of them very close to achieve a proper connection. Otherwise, it creates a non-overlap condition. Try to make this as close as possible to avoid such problems.
      You can check whether the interfaces are in non-overlap condition or not, using contours in CFD-Post. Select the shroud boundary, and create a contour using the variable "Nonoverlap Fraction"
      If the boundaries overlap, that section will be colored blue (value =  0), if there is no overlap, then that region will be colored red (value =1)
