January 4, 2020 at 2:31 am
January 6, 2020 at 12:02 pm
Forum ModeratorCan you open the data in the Solution cell? We tend not to use CFD Post much anyway. Another option is to connect "Solution" to another Results tab: it's possible (albeit unusual) that something got scrambled in the workflow.Â
January 7, 2020 at 3:24 am
jil260
SubscriberI can open the Solution cell, but how to view the contour plots or animations not by CFD Post?
January 7, 2020 at 10:09 am
Forum ModeratorUse Fluent's post processing. Can you connect another results block to the Solution? Â
January 8, 2020 at 2:07 am
January 10, 2020 at 9:33 pm
tsiriaks
Ansys EmployeeDo you get any issue if you open stand-alone CFD Post (outside Workbench) ?
January 11, 2020 at 4:53 am
January 13, 2020 at 6:34 pm
Divya Shree Surendran
Ansys EmployeeHello,
Could you please click on the Show 3 messages at the bottom of the Workbench and paste the contents here?
Also, are you able to open CFD Post individually from Start Menu?
January 14, 2020 at 12:39 am
Viewing 8 reply threads
- The topic ‘Application failed to connect’ is closed to new replies.
1587
1386
1242
