Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › LS-RUN freezing › Reply To: LS-RUN freezing
December 26, 2024 at 7:21 pm
Reno Genest
Hello Shawn,
Run the "net use" command in command prompt and post the output here.
I am in contact with the LS-RUN developer for this problem and he said the following: "What did the "net use" give? Would be interesting to see if there is any difference in the output before and after the factory reset."
Thanks,
Reno.
