Electronics
Electronics
Cylindrical (rotational) symmetry simulation around x direction
    • Gennadii
      Hi everyone,
      Is there any opportunity to make a cylindrical (rotational) axisymmetry simulation in Maxwell where the axis of symmetry is x (not z)?
      I tried to make a model that uses both Fluent and Maxwell through system coupling, but the problem is that Fluent uses x-axis as the axis of symmetry, while Maxwell uses z-axis for symmetry.
    • Gennadii
    • MirandaH
      Yes, you can change that in Motion Setup. Type tab->Moving vector: select the rotating axis
      • Gennadii
        Hi MirandaH,
        I am not shure that we speak about the same thing. I want to use magnetostatic simulation in 2D axisymmetric geometry mode with "cylindrical about X" not Z axis. Is it possible?
