December 18, 2024 at 6:46 pm
Hus.Ansys
SubscriberHello and hope all are doing well.
Any Idea on how to be able to output results as an exported text files.
My input parameter is the thickness below:
And I want for multiple input thickness values to export a text file of the below surface temperature resultÂ
Any idea how to since normal input/output parametric study is limited to certain output values like min/max single results?
Thank you! -
December 20, 2024 at 2:43 pm
Aniket Chavan
Forum Moderatorplease check:
https://ansyshelp.ansys.com/public//Views/Secured/corp/v242/en/act_script/act_script_examples_write_contour_results_onto_file.html-Aniket
