Ansys Learning Forum Forums Discuss Simulation Photonics Problem on recording the E field in 2d polarizer simulation Reply To: Problem on recording the E field in 2d polarizer simulation
xuanlunhuang20
Hi Amrita,
I used the s-parameter group to record the reflection and transmission in the same simulation. The reflection is 97.5% and the transmission is 1.4%. This is the screenshot.
I also set a seperate 2D-z normal monitor "myR" above the source in the simulation, to serve as a verification, whose recorded value is 97.6%.
The physcial quantity I'm recording is Electric field intensity.
I also set a 2D Y normal time monitor to record the field, the following is the screenshot at two time, where we can see the field transmits through the structure.
