Ansys Learning Forum Forums Discuss Simulation General Mechanical Rivet and double riveted joint Reply To: Rivet and double riveted joint
deepesh.p.gurdasani
ok. But in beam connection we get to choose the surface areas of imprints , right ? so on first plate top and second plate bottom, both the areas can be selected. Any specific reason that this wll give incorrect answer?Â
