December 13, 2024 at 9:53 am
Tim T
SubscriberI encountered the following error while using the Sph algorithm for solving:*** Error 41434 (SOL+1434)
Error encountered in SPH neighborhood search routine.
Please check mest### file for detailed information.The version of the solver I am using is R12.2.1 mpp,What should I do to solve this problem?
December 16, 2024 at 11:24 pm
Reno Genest
Ansys EmployeeHello Tim,
Have you checked in all the mesXXXX files for a more meaningful error message? In MPP LS-DYNA, each core will write its own mesXXXX file. For example, if you run on 4 cores, you will have mes0000, mes0001, mes0002, and mes0003 in the working directory. A meaningful error message may be on only one of the mesXXXX cores depending of which core encountered the error.
If you ran on many cores in MPP, we have a webapp to help you extract error messages from mesXXXX files:
https://nagasairam112-check-dyna-errors-error-dyna-check-rq20je.streamlit.app/
You can drag and drop all mesXXXX files to this webpage to extract error messages.
Let me know if this helps or not.
Reno.
December 30, 2024 at 12:39 pm
2551450404
SubscriberI also had the same problem in simulating the problem with sph on the mpp solver, and the same error was reported. Have you solved it?
March 3, 2026 at 5:38 pm
SatarLPrasanna
Subscriberhow to deal with this type of error if isph analysis is done
March 3, 2026 at 6:05 pm
Reno Genest
Ansys EmployeeHello,
Please create a new thread for the iSPH question.
Thanks,
Reno.
