Ansys Products
Ansys Products
Beam Connection for Three Plate
    • AG_07
      Hi everyone,
      I use beam elements instead of bolt connections in parts consisting of 3 plates.
      As seen in the figure, I proceeded by selecting the washer surfaces of the first plate and the last plate to create the connection.
      But how can I establish contact between the mid plate and this beam element?
      Under Connections, all bodies are defined as frictionless. Can I continue without establishing contact by acting like a body in the formed beam element?
      Can you help me on this matter?
      #question #discussion
    • Deepak
      Thank you for reaching out to the Ansys learning forum.
      This question looks like a duplicate of the original one - Beam Connection for Three Plate. A reply is provided to your reply. Please post if you have any replies to that question itself.
      I will close this question for further replies and delete this question to remove duplicates from the forum. Kindly refrain from posting duplicate questions in the forum.
      Thanks
      Deepak
  • The topic ‘Beam Connection for Three Plate’ is closed to new replies.
