Ansys ACP Delamination Fracture
    • nickmiddleton22
      I am trying to use ansys ACP to model a delamination fracture. However, it is only possible to make the fracture laminae from a 2d plane. How do you make a frature in the mesh between the laminae when the geometry from which it is based on is 2d. I need to know how to model the complete delamination fracture with various fiber orientations. I have been unsuccessful in making a 3d simulation work on my own. Thank you for your assistance.
    • ashish.khemka
      Please see if the following posts are of any help to you:
      how to create a crack on a 3D surface body in ANSYS workbench?
      Cohesive Zone Model Delamination Solution Results
      Ashish Khemka
    • nickmiddleton22
      I need to make the crack along the same plane as the surface. If the surface is generated on the XY plane, How to I make the crack appear on the XY plane in the mesh component?
    • ashish.khemka
      You can use an arbitrary crack: 5.5.4.1. Crack Overview
      Ashish Khemka
