December 10, 2024 at 1:05 pm
andrea.dentis
SubscriberHello everyone,
I’m working on a project in ANSYS HFSS and have encountered an issue. I created a spiral in DXF format and successfully imported it into my HFSS project. My goal is to wrap this spiral around a specific surface, but when I attempt to use the "Wrap" operation, I receive an error stating that the operation cannot be performed due to invalid parameters. Unfortunately, I can’t identify which parameters are causing the problem. Has anyone faced a similar issue or could suggest possible steps to troubleshoot this? Any insights on which parameters might commonly trigger this error would be greatly appreciated!
Thanks in advance for your help!Â
December 17, 2024 at 11:54 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Please share the steps you have followed for wrapping the object to guide you better.
Kindly go through "Wrap Sheet Command" section of the HFSS help document if you have not gone through it already.
Best regards,
Praneeth.
4683
1565
1386
1242
