Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Rocky tutorial 18 and 23 › Reply To: Rocky tutorial 18 and 23
Thank you for your help. I just checked and my version is 24.1.0. I should unistall this version and get a more updated version. If I want wait for 2025 R1, do you know when is the release date ?Â
I also have a question regarding one of my simulations, Im doing a CFD-DEM simulation for different particles density, I tried simulating 950 KG/m3 650 and 300 for 10s. for the 300kg/m3, around 4s, particles started to overlap and Rocky needed around 200 volumetric iterations and I was observing unrealistic results and system was going to divergence. everything else is the same for all cases. do you know what could be the problem ?
my cfd time step is 1e-4 s.
Best
Saeed
