Ansys Free Student Software
The solver failed with a non-zero exit code of 1
    • kwg97
      Hi.
      I'm working on polyflow on workbench 2024 R1 and i got a error message that
      'Update failed for the Solution Component in Fluid Flow(Polyflow).
      The solver failed with a non-zero exit code of : 1 '
      And i didn't get any methods for solving this issue
      How to resolve this?
      Thanks!
    • Prashanth
      The error message indicating a non-zero exit code of 1 typically means that the solver encountered an issue that prevented it from completing the solution process successfully. Ensure that the model setup, including the materials used, is correct. Incorrect setup can often lead to solver issues
