Mesh controls grayed out
    • Sam Fares
      I am using Ansys Mech Pro 2019 R3.  For some reason all mesh controls are grayed out. i have one single body that i selected, but i can't insert any mesh methods.
      Thanks!
      Sam
      Is that because you have an STL facet body and not a solid body?  You can't mesh facet bodies.  Go back to SpaceClaim and right click on the facet body and Convert to Solid.
    • Sam Fares
      Hi Peter:
      The following is what i have in spaceclaim. It shows it is solid. Thanks!
      Show the Workbench arrangement of analyses. It could be that the mesh is defined in some other block.
    • Sam Fares
      You are correct Peter! it has been 6 months since i last used Ansys. A bit rusty
      Thanks you!
      Sam
Viewing 4 reply threads
  • The topic ‘Mesh controls grayed out’ is closed to new replies.
