Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › [Fluent solution] Import 2D mesh with hanging nodes › Reply To: [Fluent solution] Import 2D mesh with hanging nodes
November 12, 2024 at 7:10 am
541426117
Thank you for your reply. I need to use CGNS format due to certain requirements. May I ask which Fluent versions may be able to handle this issue and treat refined cells as hanging nodes instead of converting them into poly cells?
