Electronics
Electronics
‘Geometry does not comply with pure rotation motion!’ and ‘m2dfs_solve’
    • jjh4804a
      Running the same model on each version results in the following error.
      2020 R1 - Error: 'Geometry does not comply with pure rotation motion!
      2019 R2 - Error: 'm2dfs_solve'
      I tried two ways
      1. Mesh > initial mesh settings > use slider > change
      (Try two versions)
      2. Tools > Options > General Options > Desktop cofiguration, then check the first box
      (There was no box in the 2019 r2 version)
      I want to know the solution. Please.
    • Timos
      Hello, according to the error 'Geometry does not comply with pure rotation motion!' there should be an issue with the geometry / band of your setup. We would need further information in order to help you.
      Thanks!
    • jjh4804a
      Hi Timos I solved this problem. Thank you for your heart.
