Ansys Learning Forum Forums Discuss Simulation General Mechanical Ansys Fluent- Error in Transient flow analysis of VAWT Reply To: Ansys Fluent- Error in Transient flow analysis of VAWT
The VAWT zone is rotating about a point and axis. If that's the only motion set up and you're seeing the above the only setting that can cause it is if the axis is wrong. What is the centre point of the VAWT?
