TAGGED: coupled-field, external-data, mechanical, thermomechanical
November 5, 2024 at 2:53 pm
paaulocz
SubscriberI am trying to develop a transient thermo-structural analysis with strong coupling, so I am using the coupled field transient module. For my load, I am considering pressure and heat flux. Since this load varies along the length and over time, I am using external data.
However, I am unable to apply the loading to the structure. The heat flux is not recognized in the imported data, and although pressure appears as an option, when I try to apply it, I get the message: "The data in the worksheet is invalid. Please correct before proceeding to import."
I didn’t encounter any issues when using the modules separately: transient structural and transient thermal. However, I believe this would not be strong coupling, as I intend.
Could anyone confirm if it is indeed possible to use external data with coupled field transient? Also, would it truly be a weak coupling when using transient structural and transient thermal separately?
November 5, 2024 at 3:20 pm
ErKo
Ansys EmployeeHi
In 2024 R2 heat flux is available - so pressure, heat flux, convection, temp., thermal condition are all available in 2024 R2 latest release - perhaps try and use the latest version.
All the best
Erik
November 6, 2024 at 12:25 pm
paaulocz
SubscriberHi Erik,
Thank you very much for the information. I will look into the possibility of changing the software version.
Regarding the other question, since pressure is available in the version I'm using, I tried applying it from the external data, but I encountered the message “The data in the worksheet is invalid. Please correct before proceeding to import.” Have you come across an issue like this before?
In the external data, I have x-coordinate, pressure, and heat flux for various time intervals. As mentioned, pressure is available, but heat flux is not. I tried applying pressure, but the error above occurred.
5969
1307
