Ansys Learning Forum Forums Discuss Simulation General Mechanical Inversed Contour Legend Issue in MAPDL When Changing Legend Position Reply To: Inversed Contour Legend Issue in MAPDL When Changing Legend Position
ErKo
Hi
As far as seen this is the way it shows the contour legend when you set it to left or right of window (/udoc command).
Do not think there is much that can be done as it is the way it is done in this case (we will still check if there is some form of workaround).
All the best
Erik
