Electronics
Electronics
Error parsing expression: “pwl($Tensile_modulus_with_temperature_462,Temp)”…
    • alexandre-antoi.bourrieau
      I am mixing 3D layout component + HFSS component in HFSS 3D and I got this error :
      While parsing expression: "pwl($Tensile_modulus_with_temperature_462,Temp)", an error was found near character 46.
      Any idea ??
      Ok iyt seems there is a bug when using 3d-layout component and 3d component which contain material from "Granta Materials" because when we use them, it add dataset on the project :
      After importing theses components whith these materials, the datsets are imported into the global project and they cannot be deleted.
      I think a solution is to clone the material without the dataset...
    • Aymen Mzoughi
      Please reach out to Ansys customer support and provide your project.
      Just a reminder that you may use Ansys Community Feed to develop your network and foster community by joining the appropriate community group and making connections. If you are interested in Electronics content, please join the Electronics group (link - https://innovationspace.ansys.com/community/groups/?electronics-community/)
      I have replaced all “granta materials” in each components (3D components and layout coponents) by my own material by copying the values and so I have no more dataset now and no more errors with the dataset "$..."
