October 23, 2024 at 7:13 pm
javat33489
SubscriberHello everyone, I am simulating the movement of a ball under water flow.
The liquid with the speed of 7 l/s moves the ball towards the saddle (from right to left), gravity is also indicated from right to left (in fact, the pipe is vertical).I am using 6DOF and remeshing.
But during the solution I get the error negative volume mesh:I reduced the substeps and remeshing interval but it did not help:
I also strongly crushed the grid:
but it did not help either.
I am using k-epsilon.Tell me what else can be done?
October 24, 2024 at 7:36 am
948185722
SubscriberTry restricting the movement of the ball perpendicular to the pipeline
October 26, 2024 at 5:49 pm
javat33489
SubscriberI will try sir, please tell me how to do it?
October 28, 2024 at 12:29 pm
Federico
Ansys EmployeeWhen you define your 6DOF properties, you can select Translational 1DOF. You then need to define the direction of motion (whatever the horizontal direction is in your screenshots)
October 24, 2024 at 1:58 pm
Federico
Ansys EmployeeRefining the mesh will further constrain your allowable time step size.
Can you show the mesh after the negative volume mesh error?
Also, I would suggest using the Unified Remeshing method instead of Methods Based, which requires more tuning.
October 26, 2024 at 5:50 pm
javat33489
Subscriber>>Also, I would suggest using the Unified Remeshing method instead of Methods Based, which requires more tuning.
I tried sir, it didn't help.
October 28, 2024 at 12:33 pm
Federico
Ansys EmployeeCan you show the mesh after the negative volume mesh error?
5649
1885
1404
1303
