LS Dyna
LS Dyna
Beam element post-processing display issues in ls-prepost
    • 646247561
      Using beam element to simulate rebar, in ls-prepost preprocessing I can see that the cross section of the beam elememt is circular, but after submitting the calculation to ls-dyna, the cross section of the beam element shown in ls-prepost postprocessing becomes a rectangular cross section, is this normal?
    • Alex Rycman
      The information about beam cross section is included only in k-file. Therefore, while post-processing the beam elements on the result files (d3plots) the LS-PrePost will display the beams with the rectangular beam cross section (default). The workaround is to open d3plot and k-file simultaneously (File->Open->LS-DYNA Keyword+D3plot).
      Thank you,
      Alex
    • 646247561
      Thank you, your answer is very helpful!
