November 13, 2019 at 4:37 pm
nonsuch
SubscriberI am trying to model a three layer carbon fiber laminate which was made using a plain weave fiber and carbon epoxy using ACP. I am not sure which materials to select: should I use "Epoxy Carbon preepreg"? Is that the same as a layer of lamina? Or should I use "Resin Epoxy" and create a separate new material for the fiber?
Thanks!
November 14, 2019 at 5:18 pm
nonsuch
SubscriberIs this the correct place to post?
November 14, 2019 at 7:57 pm
Wenlong
Ansys EmployeeHi,
I would use "Epoxy Carbon Woven"Â as your laminate material. It considers the combination of woven carbon fiber and epoxy resin.Â
Bests,
Wenlong
- The topic ‘Carbon Fiber’ is closed to new replies.
1305
