Ansys Learning Forum Forums Discuss Simulation Photonics How do I implement a custom optical signal in interconnect? Reply To: How do I implement a custom optical signal in interconnect?
A00835327
I designed an spectrometer, an I'm testing it with several optical signal to see if I'm capable of reproduced the original spectrum at differents wavelengths. I used CW lasers with a combiner to test if I was capable to reproduced several combinations of wavelengths and the test was positve. However, the true test is an special spectrum , and this spectrum has a fluorescence signal over all the wavelengths I'm testing. That's my problem, how do I aggregate this fluorescence signal over al the waverange?.
Thanks for helping me.
