Ansys Learning Forum Forums Discuss Simulation Fluids Non-Intersected faces found for matching interface periodic-walls Reply To: Non-Intersected faces found for matching interface periodic-walls
zoelle.wong
ah i see- the angle between the two faces are 90deg. should i change the mesh such that the angle between the two faces is 180deg?
