Ansys Learning Forum Forums Discuss Simulation General Mechanical Modal Analysis- what is the purpose of Environmental Temperature Reply To: Modal Analysis- what is the purpose of Environmental Temperature
Erik Kostson
Hi
happy it helps.
If you refer to how to define such a table (Temp: 22    200000000000  Pa  0.3
Temp: 100    100000000000 Pa   0.3)
in Engineering data, then the below shows some screenshots of that:
https://innovationspace.ansys.com/forum/forums/topic/influence-of-temperature-dependent-youngs-modulus-on-thermal-stress/
If it is about making a parameter, then I will create a new post (see below), so we can close this one here as others might find your initial question interesting and the answers helpful.
https://innovationspace.ansys.com/forum/forums/topic/parametrizing-material-properties-youngs-modulus/
Erik
