Ansys Products
Ansys Products
Fluent DNB simulation
    • Kinjal
      I am carrying out flow boiling simulation in fluent to predict DNB. I am starting with heat flux of 0.5Mw/m^2 and increasing it step by step and monitoring temoerature. When the chf is reached wall temperature will increase suddenly and the solution will diverge. At first when I was usimg sauter mean I was able to get the diversgence but at that time it was giving wrong results for WHFP i.e. my evaporative heat flux was going above total heat flux which is not possible. Then I kept the boilig dia. default for the secondary phase and WHFP gave the correct results but now I am not able to predict DNB. What can be the issue?
      Lots of things. An overuse of TLAs may play a part, but I'd start by looking at the mesh and other solver settings.
    • Kinjal
      Hello the above problem is solved. Now I have got a recalibrated model for nucleation site density, udf for which is given below
       #include "udf.h"
       #define C 42.27
       #define n 4.67
       #define delta_T_ref 1
       DEFINE_BOILING_PROPERTY(nucleation_site_density, f, t, c0, t0, from_index, from_species_index, to_index, to_species_index)
         real nuc_d, subcool;
         real T_w=F_T(f,t);
         real T_SAT = C_STORAGE_R(c0,t0,SV_SAT_TEMPERATURE);
          /* Subcooling calculation: T_w - T_l */
         subcool = T_w - T_SAT;
          /* Calculate nucleation site density using the formula */
         nuc_d = pow(C,n) * pow((subcool / delta_T_ref), n);
         return nuc_d;
      } This seems correct but why is fluent crashing while predicting wall temperature and printing on console bisection method cannot find wall temperature. How can I resolve this issue, Please help
      Not sure, does it behave running on a single core?
    • Kinjal
      No multiple cores. Hello can you please help me.
    • Kinjal
      The udf is correct right?
      Bisection method cannot find wall temperature bounds for the face with ID 557 on the boundary 'heated_wall' centered at ( 0.243575 0.005500 ). Skipping this face.
      Bisection method cannot find wall temperature bounds for the face with ID 558 on the boundary 'heated_wall' centered at ( 0.244252 0.005500 ). Skipping this face.
      Bisection method cannot find wall temperature bounds for the face with ID 559 on the boundary 'heated_wall' centered at ( 0.244928 0.005500 ). Skipping this face.
      Bisection method cannot find wall temperature bounds for the face with ID 560 on the boundary 'heated_wall' centered at ( 0.245604 0.005500 ). Skipping this face.
      Bisection method cannot find wall temperature bounds for the face with ID 561 on the boundary 'heated_wall' centered at ( 0.246281 0.005500 ). Skipping this face.
      This is what it says
      Bisection looks to be parallel, but could be a red herring. I assume you're retaining all data? Can you try on a single core and post the wall boundary settings that you're using?
    • Kinjal
      As this is a simulation for predicting CHF I am giving 0.5MW/m2 heat flux initially and increasing it in steps of 0.5 after wall tempature is stabilised. This is controlled by udf. I tried on single core. It doen't make any difference.
      And is anything else set on the wall bc?
    • Kinjal
      No nothing
      Is it a thin wall?
    • Kinjal
      The geometry is a simple 2d rectangle
      Axis symmetric BC is used and on the wall heat flux is applied in steps
      It is like heat flux is constant until temparture is stabilised and it is increased after that. But while I am monitoring heat flux file it is changed and it drops suddenly when boiling begins. Inout should not change right.
      Which heat flux? Pictures of panels will help.
    • Kinjal
      #include “udf.h”
      DEFINE_PROFILE(dynamic_heat_flux, thread, position)
          int n = N_ITER;         // Get the current iteration number
          real q0 = 0.5e6;        // Initial heat flux (W/m^2)
          real q;                 // Heat flux at the current iteration
          real chf = 3e6;      // CHF value (W/m^2)
          // Determine the heat flux based on the iteration number
          if (n <= 500)
              q = q0;
          else
              int i;
              q = q0;
              for (i = 500; i <= n; i += 300)
                  // Check if q approaches 75% of chf
                  if (q >= 0.75 * chf)
                      q += 0.1e6; // Increment by an additional 10% step
                  else
                      q += 0.5e6; // Increment the heat flux by 0.5e6
          // Print the heat flux value after every 300 iterations
          if (n % 300 == 0)
              Message(“Iteration %d: Heat Flux = %g W/m^2\n”, n, q);
          face_t f;
          begin_f_loop(f, thread)
              F_PROFILE(f, thread, position) = q; // Apply the heat flux
          end_f_loop(f, thread)
      this is how heat flux is applied
    • Kinjal
      Why not use a profile or just link flux to iteration number with a limit? Your code isn't monitoring anything in Fluent, it's just checking the iteration number.
    • Kinjal
      But this works when I am using Lemmert Chawla model from the fluent direcly but when it is given through udf it is causing problem
      And how does the UDF differ from the model?
    • Kinjal
      Even if I am making udf same as a model it is not working for me. Also the heat input which I give changes when the udf is activated
      You have two UDFs. Which one alters the heat flux you're reporting, and what are you reporting?
    • Kinjal
      So heat flux udf I am using and it works well when lemmert chawla model existing in fluent is selected, but the combination of nucleation site density and heat flux udf is causing heat flux to change a lot and results are unphysical. I want to modify the existing Lemmert Chawla model for my simulation as values need to be different, but this is not working. Can you check if there is issue with my NSD udf which I have posted above.
      We don't debug UDFs. So, the problem is not with the heat flux it's only when you turn on the nucleation UDF?  I'd not use single letter variable/constants and always define a value as 1.0 if it's real just in case you've accidentally tagged something that predefined as an integer: I learnt coding with FORTRAN so have a few old habits.
    • Kinjal
      I don’t know what exactly is the problem. How can I modify the existing model in fluent then. By using default model I am getting very high wall superheat values which are unphysical, hence I am recalibrating. But problem is surely not with the heat flux as it works well for default.
      Nor do I as you haven't shared what you're monitoring to see why you think it's not working. What is the Heat Flux Report that Fluent is reporting? NOT the surface integral.
    • Kinjal
       i have shared the image above.The heat flux I have shown
      Here I have given constant heat flux of 3MW/m2 and see how it is fluctuating even though it is an input. And also wall temperature is changing abruptly
      Which is the SURFACE INTEGRAL. Please check the value from the FLUX REPORT.
    • Kinjal
      But why to check surface integral? Here the problem is with the udf. Am I calling wall temperature in a correct way. Can you please confirm on that?
      What temperature call?
    • Kinjal
      in udf which I have shared above
    • Kinjal
      I amusing same model as that default model in fluent for nucleation site density byt through udf. The reason for this is I want to change the values of constants in the default model. But the udf doesn't give same results as that of default model. Why is it happening.
      Ah, the first UDF. You're calling the wall facet temperature, what does the documentation show? Note, UDFs are not fully supported - you need to check documentation carefully.
    • noelia.bouzas.jamardo
      Hi, I am experiencing the same issue.
      My Lemmert–Chawla nucleation site density UDF worked correctly in ANSYS Fluent 2023 R2. The implementation is essentially the same as the one shown in this thread. However, after moving the case to Fluent 2024 R2, the UDF no longer works and Fluent reports the following error:
      Bisection method cannot find wall temperature bounds for the face with ID 557 on the boundary ‘heated_wall’ centered at ( 0.243575 0.005500 ). Skipping this face.
      The built-in Lemmert–Chawla model works correctly under the same conditions. The problem only appears when I use the UDF implementation.
      Has anyone found the cause of this change between Fluent 2023 R2 and 2024 R2, or a solution for using a wall-temperature-dependent nucleation site density UDF in Fluent 2024 R2?
      Channel Partner
      Can you check what the wall definition is? Ie internal, external, wet etc relative to the cell zone? I am not ruling out it being a solver problem, but I've not seen reports of issues during testing: also try 26R1 as we've moved on a bit and 2024 is so last season... ;)
      Thanks for your reply. I checked the Fluent release notes and saw that the wall-temperature calculation and the bisection method for heat-flux and coupled boiling walls were modified between Fluent 2024 R1 and 2024 R2, particularly the procedure used to determine the initial wall-temperature bounds.
      Since my nucleation-site-density UDF depends directly on the wall temperature through T_w = F_T (f,t), I wondered whether this value might not be updated consistently with the trial wall temperatures used internally by the new bisection algorithm. This could explain why the built-in Lemmert–Chawla correlation works correctly, and why a constant nucleation-site-density UDF also works, while the temperature-dependent UDF that worked in Fluent 2023 R2 no longer works correctly in Fluent 2024 R2.
      Could you provide some more information about the changes made to the wall-temperature calculation and bisection method in 2024 R2? In particular, is F_T(f,t) updated with each trial wall temperature before every call to DEFINE_PROPERTY? I would also be interested to know whether built-in correlations and UDF-defined boiling properties follow the same calculation path, and whether this implementation has changed again in Fluent 2026 R1.
      I will also check the wall definition and test the case in Fluent 2026 R1, as you suggested.
      Channel Partner
      I can't provide anything that's not "public", with documentation being the definition of "public" in this case. I can raise the point to see about more details in the documentation, but that's not going to be a quick process.
      Let me know how you get on with 26R1.
      Channel Partner
      Treading carefully to remain within the rules. You've shown 23R2 is working, I suspect you'll not be successful with 26R1. It's been logged but I can't comment further. I would suggest trying in 27R1 and releases after that.
Viewing 35 reply threads
