3D Design
3D Design
Select a face by its angular position in SpaceClaim scripting
    • philipp.mader
      I have a body with a hole in the middle which is divided into 5° sections. I would like to create an Excel file of the areal moment of inertia of the cut faces of the body in 5° steps (in my case, Ixx).
      My question is whether it is possible to select faces by their angle to the XZ plane and to output a data set in Excel.
      Philipp
    • Atharv Joshi
      Hi Philipp,
      Yes, its possible to measure the angle between the faces and XZ plane and get the output in excel.
      Once you measure the angle, you can use "if loop" to filter out faces based on measured value.
      Can you please share the screenshot of the geometry so that I can help you better?
      What exactly do you want as output in excel the measured value of angle for all faces or the moment of inertia?
      Regards
      Atharv
    • jay16441
      hg
