October 8, 2019 at 4:34 pm
abidahmad2020
SubscriberI am trying to design an antenna in HFSS, I draw a shape using polyline and made a shape using type as rectangular, but while i am validating my design. It is showing error in 3D design. Could anyone help me to solve this problem? Thank you.
October 8, 2019 at 6:13 pm
slouie
Ansys EmployeeWhat error message are you seeing?
February 25, 2023 at 8:16 am
- The topic ‘Validation Check Error In 3D model’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1363
1194
