Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Why max and mini values are the same? › Reply To: Why max and mini values are the same?
August 29, 2024 at 1:15 pm
At a vertex, you have only one value for temperature at selected time. So same value is used for max and min display
If you plot result on a surface or an edge, then you have results from all nodes on the surface/edge. So, there is possibility that the temperature could be different on different nodes and so you will have a different max and min values
